Analog to Simrad go7
Wisefam22
Lake Lanier ga
How did you get the rpm to display on your go7?
rkim808
Kauai, Hawaii
Aloha Yamaha212limiteds, Thant’s a sick install. I want to install that same unit in my AR240, the helm is almost the same. I think should be able to do the same. Can u post pics of ur transducer install too please? Nice job bro...
rkim808
Kauai, Hawaii
Haven't install the transducer yet, dont want to drill holes. But sure will once done.
Aloha, did u use the flush mount kit to install the GO7? I think ur helm dash is taller then mines in the gauge area. Can u post the measurements of the template u used to make ur cuts please?
Mahalo(thank u),
Rueben
biffdotorg
Pelican Rapids, MN
I'm posting to follow this thread. Many have talked about running that data to the Simrad. And from what many have found out is the Yamaha Waverunner engines do not put that info out in a standard form like Yamaha Outboard engines.
So if you get it to work you will have proved many folks wrong, and many more would love to hear how you did it. Good luck!
Yamaha212limiteds
Fayetteville, NC
Mahalo(thank u),
Rueben
I did not use the flush mount, But I working on a better layout, will post pictures soon. I measure three time then cut it. didn't use a template.
Yamaha212limiteds
Fayetteville, NC
I seen many thread about it, But the signal is in the n2k network, trying this will require Time and Money. But, it can be done. I'll keep you guys posted.
rkim808
Kauai, Hawaii
Oh ok, I’m still figuring out if it can even fit like how it fit in urs.
