Anchor Locker liner ideas? Trying to protect the inside...
Drfast555
195S
Hello all! 2021 195S here. Have two anchors in the locker and neither fit in the factory holders. I have note seen any commercially available mats/liners for this use.
I was planning on using some type of mat, but looking for ideas!
Babin Farms
Lower Alabama
Seeing your going to have to cut anything to fit in the locker I would maybe try something like this, that way you can still fasten them together in the locker. Maybe double them up for more cushion.
212s
1000 Islands
212S
We picked up a rubberized outdoor doorstep mat and put it in the locker to keep the anchor and chain from moving around.
white2kstang
Austin Texas Area
mrcleanr6
new jersey
275SD
You can get self adhesive rubber sheets in different thicknesses from mcmaster.com. I have even gotten it in white.
Sotally Tober
San Diego, California
Convert that area to store your fenders and lines... forget that its labeled as an "anchor locker". Buy a box anchor (Box Anchor — Slide Anchor) and store it in a folded position in one of storage spaces.
Literally, throw your box anchor over board and forget about it.........no setting needed.
BigPapiBT
Even the small box anchor won't fit in the anchor locker? Seems like a natural spot for it, but maybe too long when folded?
ChrisM
Rock HIll, SC 29730
Chaparral
VR
I noticed that my anchor in it's front locker was starting to gouge the fiberglass some while under way at higher speeds.
After restoring old splash guard material in my truck fender wells, I used the left over material in the anchor locker.
It's masticated rubber. I purchased from the link, off their E bay site..
Detroit Muscle Technologies, LLC
Had my boat out all day today, took a pic of the rubber pad.
OF COURSE NOW I SEE THE CAUTION STICKER...!!!!! :eek:
white2kstang
Austin Texas Area
Small fits in our 2019 AR195 with the danforth and 150ft rope.
zipper
Boston Whaler
I used a left over piece of 1/2" cow mat, @Babin Farms might know the stuff, to use as a pad inside the locker to use as a bumper for the anchor. The Seachoice sliding ring anchor was a POS, would not hold and I lost confidence in it. I bought an 8# West Marine Danforth style galv. anchor to replace it.
It has held every time on our lake bottom. I did have to cut an inch and a half off of each end of the stock to hang it in the locker. Probably could have moved the mounts instead. It did not matter it performs well. The shank rests on the bottom of the locker on top of the chain and rode. That area could be padded too if you desire. It does not move or swing around in there. I do not recommend modifing your anchor, but it worked well for us.
FSH 210 Sport
Tranquility Base
In another thread another member posted using this product for the anchor locker.
white2kstang
Austin Texas Area
I ordered a few of these tiles to try out. Supposed to be here yesterday... was delayed.
mrcleanr6
new jersey
275SD
Been using dridek for years an the yachts. They have it in burgundy color to match my hull so i ordered enough to do my ski locker. Much better than that stuff yamaha gives you. Dridek is great. If cut to size right then it stays put and is super durable. I dont know how you would get it to confirm to the inside of the anchor locker but if you can then it would work great
