flyingnugget
- Newnan, GA
- 255XD
ok you guys need some insight here.
Have 2014 242LS and I have a leak somewhere. I've filled the rear area with water and didn't have any leak out that I could see. Checked the rub rails and all looks good there.
Took the boat out for its first run the other day and noticed the bilge pump put out a pretty good amount of water when we had stopped and were hanging out on the back. Now it was just me and a buddy and we never had a any water come high enough when we slowed down and stopped to come over the rear seats to fill the clean out ports.
So, when we pulled the boat out of the water there was a pretty good amount coming from the drain plug and also the clean out ports were full of water
So, if the clean out plugs are sealed properly, which they seem to be, where is all that water coming from that gets on top of them? Any way to seal the tubes? And, can that water in the clean out tubes get inside the rear hatch area that the bilge has to pump it out? I really dont want to take the boat in for work at a dealer and ruin most of the beginning of the summer.
Watcha got??
Watcha got??
