Nivekot
- Limited S
For those that run antifreeze through your engine cooling system(s), do you buy antifreeze based on the burst or freeze temperature? I know West Marine carries antifreeze labeled as (-50°F, -60°F, -100°F, etc.), which is the burst temperature, but actual freeze temps are much higher. For example, the West Marine -50 has a burst rating of -50F, but freeze rating of +12° to +16°F. I’m in northern Ohio, will this (West Marine -50) be okay as winter temps can fall in the single digits or slightly below 0F??
