  • Gantlin Products, the creator of the WAKE WEDGE is currently running a Group Buy for those of you that want a better, cleaner wake to surf behind your Jetboat! This Group Buy expires on April 1st, so get your order in ASAP to jump on this once a year discount on the Wake Wedge. The discount could go as high as 15% off!
    (You can click the X in the upper right to dismiss this notice)
Any tips or tricks to getting a 242 in the garage?
Ratings
11
AZ
I'm wondering if anyone has any tricks or gadgets they've come up with in order to get their boat in their garage. I currently keep my 242 Limited S in a warehouse but eventually want to bring it home every once in a while. I have 8' doors on the garage. I think if i remember correctly that the winshield is 8' tall on the trailer without the wake tower. Correct me if I'm wrong.
Andy S
Ratings
3,139 39
Chapin, SC 29036
Cobalt
2 tricks I know if you only need a couple of inches. FYI - These tips don't work on your man parts.
1. If you have an adjustable hitch, drop it as low as it will go when backing into the garage.
2. Lower the air pressure in the trailer tires when backing into the garage. Don't forget to refill the tires in the garage.
GoVols01
Ratings
205 10
College Grove, TN
There's an extensive post I had for getting my 212X into my 8' garage from 1 year ago - search for it.
I highly doubt you could get the 242 through an 8' tall garage opening, considering my 212X literally clears it by a gnat's nut hair. All this while the bimini is completely removed and the tower's retainer wires removed.
