Geiger41
- Egg Harbor Township NJ
- Boatless
- NA
- Other
- NA
We use RV antifreeze in our PWCs. Eco-friendly, as you say.As far as spilling antifreeze into the environment... every I/O that gets "winterized" out there does this (in an area where winter means freezing temps). I used eco friendly antifreeze when I would winterize my Cobalt and I have dogs. I just made sure to spray it off the concrete (into the grass) when I was done.
Some may say the funnel idea may not provide enough pressure if you run the engines longer than normal, as if they were not on a hose. Not arguing that point, if it makes you feel safer you could always grab one of these drill pumps for a few bucks. Thats what I use and it does the trick.
I am only bringing this up due to a discussion that was had concerning those expandable hoses. Many members on here seemed to believe that the expandable hose did not provide enough pressure to circulate the water through the engine and that a normal hose was needed/recommended. This is what made me think of the funnel as not having enough pressure, regardless you are probably not running the engine long enough anyway that any damage could occur.It's getting the cooling needed from the anti freeze.
