McMark
- Monongahela, PA
Here is an off the shelf replacement knob that has 3/4” more engagement than the stock forward swept AR Knob. This amounts to about 11 more turns than factory. All 303 stainless. Similar tensile strength as 316 stainless. Less corrosion resistance than 316 or even 304. Use your existing black plastic cone washer that comes with your factory knobs. You may be able to cut the stud length down to get good engagement and use the spring to hold the knob out. It will be a balancing act though. I have not ordered any yet but I will be ordering in the next week to verify the fit.
Use at your own discretion.
https://www.mcmaster.com/#6091k54/=19w7lnc
