AR195 break-in/ECU programmed limits?
stevenk2
Does anyone know if the ECU for the SVHO in the AR195 is programmed to limit the RPMs during the break-in period, or is it truly a manual process? I know that the Rotax in my old Scarab was programmed to limit the RPMs until you cleared the break-in hours, so even when you ran wide open during break-in, it limited you to something like 5000-5500 RPM.
DavisAR195
Happy Valley, Or
MasterCraft
On my 2017 AR195 the break in was not programmed.
stevenk2
Anyone have a 2019 that would be able to chime in? Also, how bad is it if the 5000 RPM limit is exceeded occasionally during the initial 90 minutes of runtime?
jEt_jAk
SoCal
AR195
On 2018 it also is manual. I wouldn't worry too much if it was exceeded but I tried to stick to the break in routine.
mwalker4
Delaware County, Ohio
It is interesting there is still a formal break in period for these engines. Most new cars do not have a formal break-in period and break-in oil anymore. Of course there are plenty of people on the forums who recommend the first oil change at 500 miles, but your Honda maintenance minder computer won't recommend the first service until past 10,000 miles.
haknslash
Lake Martin, AL
Moomba
A car doesn’t have near the loads on it that a marine engine constantly has.
stevenk2
On any new cars I've ever bought, I get used to seeing a few miles on the odometer from the dealership and generally didn't worry too much about it. I'd imagine that with the boat, it was probably taken out on a couple of test/demo runs by the dealer, and probably isn't a big deal (it's reading .9 hours on the engine on the Connext screen). That and given the durability of the SVHO engine, I'm sure it's probably fine. I just didn't know if there were pre-programmed limits on the engine during break-in, and/or if I should continue to follow the break-in procedures for the next 30 or so minutes of runtime remaining on that.
Looking at the flipside, I guess this means that I don't have much time left before I can run her wide open - they did me a favor by taking care of the bulk of the break-in period already. :)
Blue Hawaiian
Toronto, Ontario, Canada
Yama Ha-ha
AR195
There is no limiter holding rpm down; I can easily go to ~7300 rpm, but the dealer asked me to limit the rpm below 5300 rpm until 25 hours and the first oil change.
Rlc1z
Whiteland,In
Wow!😲 That’s a lot of hours for a break-in to keep rpm under 5300!
Yama Ha-ha
AR195
Yes, I agree, maybe the whole summer for me.
I_squared_r
Colombia/South FL
My source is the collective knowledge I have over years in power sports and auto mechanics.
The break in period is done by the manufacturer. The idea is wear (or seat) the piston rings in the cylinder. It’s a delicate process that ensures maximum performance and efficiency. It’s in the manufacturers best interest to do this in the QC process.
My disclaimer is that I’ve never actually visited a factory and confirmed this myself. I’ve heard of this over the years and it sounds reasonable. I’ve never followed break in procedures and enjoyed the product ASAP. I only observe break in procedures after building engines and even then I don’t spend more then 10 minutes.
Yama Ha-ha
AR195
Thanks!
