AR195 "exhaust clamps"
EmeryZ28
Just heard from my service adviser. My boat is in for some yearly maintenance. oil change and such. They told me of two issues. One is some sort of coupler or rubber piece that has to do with the impeller is swelling and needs to be replaced, this is a known issue and covered under warranty. The other thing he brought up was exhaust hose clamps. He said they are rusting and need to be replaced, if not they could come lose and exhaust gases would escape, be noticeable to passengers in the boat etc. He says they are located under the access panel under the swim deck. I am pretty certain I know what he is talking about. I am a pretty handy and mechanically inclined guy, I wrench on cars often. I think I am going to tackle this project myself as they want $250 for parts and labor. Has anyone else experienced this? The boat is only 2 years old, but 90% of its use is in saltwater.
Scottintexas
Corinth, TX (DFW)
I'd be interested to better understand the coupler/rubber piece they are replacing, we've not heard of that issue before,
I wouldn't doubt the clamps are rusting or showing some rust, I doubt the exhaust gas death theory though, that's spreading it on a little thick, although if one of your cooling hoses comes off you could have issues,
If you're handy it's easy to repair yourself, maybe check out the threads of adding a second bilge pump to see what it looks like under the panel but's it probably would be a good idea to replace every clamp you see, even in the engine compartment with stainless steel since you're primarily salt water usage,
it might be a good time to add a second bilge pump,
Cobra Jet Steering LLC
Vendor
Florida
Actually rusted hose clamps in general are a very common problem and have been for a long time, not only with Yamaha but other makes as well. I even spray them with white lithium grease to slow the process but I had to replace numerous rusted clamps this year so use good clamps and do them yourself. Back them up with a good heavy duty cable tie as well.
Vendor
Florida
There is a vibration dampener in between the engine coupler and the drive shaft coupler I would guess this is what he is talking about but I have never had one go bad even with 680 hours on them. looks like this
Beachbummer
Houston TX
Any chance it's the impeller wear ring on the pump that's swelling? that's the only impeller part I know that swells and can cause issues. For the clamps, If you are mechanically inclined and would like to save $200 do it yourself. it's probably one of the easiest $200 jobs there are.
EmeryZ28
I went in yesterday and spoke to them in person. Yes it is the impeller wear ring that is swelling and should be covered by yamaha warranty.
I also was able to see these clamps he was talking about and yes they are rusted, but a very easy fix
SCP1
DeForest, WI
212S
Can you take a picture of the the rusted clamps so I can get a better idea where I am looking.
Scottintexas
Corinth, TX (DFW)
if you remove your manhole covers next to your cleanout plug you should be able to look down and see your water box/exhaust,
you may have to pull that whole cleanout tray deck top up to see all the clamps,
You should also be looking at all your clamps in the engine bay,
2017 Yamaha AR195 (RP1800AS) Jet Unit 4 | Yamaha Sports Plaza
