AR210 Hull dimensions for trailer
DocksB
Hey all!
First time posting, so I appreciate any and all the help I can get.
I recently purchased a used (2021) AR210. It won’t be coming with the trailer, so I’ve bought one on my own, and am planning on adjusting it to fit the boat accordingly. Of course, the trailer store has told me they would custom fit the trailer for me, once the boat is on. But, I’d like to make sure I have the trailer at least somewhat close to the custom fit before picking up the boat from the water with it.
Hence, why I am here. I wanted to see if anyone has any advice, or the particular dimensions of the hull on a 2021 (same as 2020 and 2022 models I believe?) AR210 so I can adjust the trailer and bunks accordingly before picking up the boat.
Any and all help is greatly appreciated!
HangOutdoors
Royal Oak, MI
@DocksB The hulls are the same from 2017 - 2022. I would give you measurements but boat is on mine. Unless someone has theirs off off the trailer, I could probably crawl around this weekend and get you what you need if you are specific.
Also all 21' boats regardless of model have same hull shape for the years 2017-2022 and sit on the bunks the same. Except for the FSH I believe.
DocksB
Wow, that would be amazing if you could. It would be so very much appreciated. Thanks for all of this
HangOutdoors
Royal Oak, MI
Let me know what it is exactly that you need.
DocksB
I’m thinking just the length in between each the front and rear bucks
