AR210 sub location
Oscar0421
Simpsonville, SC
I am wondering where everyone has installed their sub on a 2018 ar210. I was hoping to install mine under the rear seat but the fiberglass is not straight. The only place I can think of is on the side of the driver or behind the driver seat. I only plan to do one 10” sub.
adrianp89
Tampa Bay, FL
252SE
One the side by the passenger or drive seat works pretty well. I put two 10" IB under the passenger side bench.
adrianp89
Tampa Bay, FL
252SE
'18 AR210 - it should be exact same as my SX210. Let me see if I can find a picture.
adrianp89
Tampa Bay, FL
252SE
I haven’t had any issues with it rattling.
adrianp89
Tampa Bay, FL
252SE
Ad
that looks great. Is there enough air behind the sub?
There is a few inches between the back of the sub and the hull, with that being said that area is completely open to the rest of the hull, so plenty of air.
BrentM
Did you use a wood ring behind it or screw it directly to the fiberglass?
adrianp89
Tampa Bay, FL
252SE
Yeah I used a 1/2" thick ring cut from pvc board.
