AR210 TR-1 1049cc Power??
jared24
Columbus, GA
Currently have a AR190 and looking into upgrading to the 21ft fleet. The price range of the AR210 vs 212 series is compelling however I'm having power concerns over the TR-1 engines vs the 1.8 Liter in the 212's.
Am I correct the the TR1 equivalents out to about 110HP? Would twin (220HP total) be enough to push when at it's capacity weight (10 people plus gear)? I know my AR190 struggles at times to plane when at weight capacity. Any help greatly appreciated...
NHboater693
I just took home a '17 SX210. We tested the 212 Limited and the SX210. There is a huge difference in performance. This is to be expected with a 130HP difference. Ultimately, we opted for the SX210 for our first boat due to a value proposition. We have young kids and will likely upgrade to the higher performance boat in 5 years once they are older. In the meantime this boat performs reasonably well with it near capacity. If you're looking for a rocket ship, this is not it. Hopefully this is helpful but your best bet is to test both out the same day and see what you think works for your situation.
Txjetter17
Galveston, TX
Gets less friends or make them get their own boat. 10 people would make it packed.
Txjetter17
Galveston, TX
It'll do 44 with two people and a little gear. I had 6 on board one day and it would only hit 40. Have a 2017 AR210
jared24
Columbus, GA
Not too overly concerned about top speed but would like to be able to pull a skier with a full boat/gear without straining the engines and constantly having to work the throttle to keep a consistent speed like I do with my 190. Please give me some feedback if you've been in this situation and let me know how the 210 performed. Thanks!
Bruce
Royal, AR
Perfect Pass or the similar new product is the solution to this.
If you want power I would look at used 240, 230 or 212 models that are available for less than the cost of the new 210.
CAM212SS
Knoxville TN
SS
if you are pulling tubes and skiers with people on board, i feel you will be disappointed in the long run. My first jetboat was a 210. With 6 or so people on board, tubing and skiing was a challenge for the boat seemingly to me.
Since then, we upgraded to the 212ss and have zero complaints on the power
Jebinok
Conway AR 72034
buy your 2nd boat first. Get the 212
NHboater693
I haven't pulled a skier yet and I don't load the boat to capacity so I can't speak to your question directly. My guess is given how you plan on using the boat, you're better off with the 212.
Ancient canoe
Denton TX
Regardless of power 10 people + gear is going to be tight on the boat (unless a lot of them are small kids). If that's a normal day for you, I would get a bigger boat.
seabass2020
Not sure why some are complaining about the power. Maybe it's their elevation, but I have a 2017 210 and I think the power is excellent. I'm at 900ft elevation. With 2 adults and 3 small kids, my top speed is 41 with top up and 43-44 top down.
My buddy has a 2017 242x, and we raced from a stop. Mine was much quicker to 40mph, but once i reached top speed, the 242 pulled away. Overall I have been very pleased with the performance of the boat. I've heard that higher elevation may require different impellers to get better performance there.
By the way, my MSO said the HP for this boat is 230.
