Ar230 07- what should the Rpms
Addison
Cobalt
I just bought a 07 ar230 about a month ago. What should the Rpms run at while cruising on the lake? They were at 8k at 35mph
Beachbummer
Houston TX
Better than mine. I usually get 32 at 8200, but my impellers need some work.
Beachbummer
Houston TX
You should be able to cruise at any RPM above 7200+ or so. as long as you are planning the boat is happy. The faster you go the more fuel you burn, but you did not buy a boat to save a few bucks on fuel!!!
Babin Farms
Lower Alabama
It sounds about right. Usually I try to stay about 8k when cruising
Addison
Cobalt
Alright sounds good, I was just wondering we took our boat out to table rock last weekend and I let my dad handle the boat and he was all worried bc the Rpms were higher to him. he comes from a cobalt thank you guys,
Beachbummer
Houston TX
Yes,Our boats DNA comes from very high revving motorcycle engines, and pump design dictates higher RPMs, so it's all good, Our engines actually have a reduction gear inside the engines, so the impeller spins at fewer RPMs than the engine crankshaft. All normal.
