Welcome to Jetboaters.net!
I saw the post but I really can't be sure, there may be some differences. It would be interesting I know they use some pumps with the small bearings and some with the larger bearings on skies , I avoid the smaller bearing pumps since they don't hold up as well as the larger ones. I would agree that he needs to know for sure, I just don't have an answer unfortunately.
checking my dealer book at s b t The only difference in the part numbers between the boat and the ski is the boat is 78-406-01 and the ski is 78-406-02, guess they both fit but I don't know what the difference is.
You didn't say what year the ski was so checking the same years boat to ski they also use the same bearing kits, It may make a difference if the ski is a different year though.
I was wondering so I could order my dual impellers for my pumps. I didn't see an option for the AR's on the site I am ordering from. After contacting the company, they told me to order the ones for the VX/FX ski.
it should be in your manual, for my 2007 which I believe should be the same,
marking yamaha part number degrees
port 6P600 6p6-R1321-00-00 18.1'
starboard 6P610 6p6-R1321-10-00 15.1'
If you go to Yamaha Sports Plaza you can look up the part numbers for both watercraft and boat.
Then you can do a part number search also on their website.
Then click on "Where Used" and it will show where that specific part number was used on which watercraft or boat.
Then cross reference and verify.
I do it on some parts on the 2014 boats and to compare with my 2010 boat to see if Yamaha has changed anything I can improve, I have not found anything yet.
