1. Welcome to Jetboaters.net!
AR240 Tower shake fix
Discussion in 'Yamaha AR240, SX240, 242 Limited / S / X/ E-Series' started by All Seas, Jul 15, 2018.
  1. All Seas
    All Seas Member
    50
    Austin, TX
    Ratings:
    +14 / 4
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Anyone else's 240 tower shake ridiculously??????
    It's at the point where any wave and it looks and sounds like its going to rattle off. Mounts seem ok (no fiberglass cracks) but the black gaskets are cracked and sliding out from under the tower. Will replacing these fix the tower movement? Am I better off buying oem replacements or maybe a 1/2" rubber gasket and cut my own.
    I should have bought an SX and put a monster tower on it!
  2. jlknip
    jlknip New Member
    Ratings:
    +0 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Mine does the same. Haven’t found a solution yet....
  3. All Seas
    All Seas Member
    50
    Austin, TX
    Ratings:
    +14 / 4
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    I swapped the gaskets out and really did not make much of a change
    I was thinking of filled the tower with a heavy 2 part epoxy foam. It will add some weight but a few manufactures make an expanding foam that cures in low moisture/air and turns hard as concrete.
    That HAS to stiffen it up unless it's flexing from the mounting points
    • Useful Useful x 1
  4. ar240owner
    ar240owner Event Sponsor Event Sponsor
    936
    Ratings:
    +960 / 17
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    I had a monster tower on my old boat , and it shook worse !! I’m going to replace all my gaskets cause mine are doing what yours are , and tightening up everything ,
  5. All Seas
    All Seas Member
    50
    Austin, TX
    Ratings:
    +14 / 4
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    The other thing I thought of was some large foam to cover the side support bar that runs next to the glass windshield section. If the foam is thick enough to brace between the tower and the window frame, It should stop some of the side to side movement but am worried it can crack the glass.
  6. Joshua Miller
    Joshua Miller Jet Boat Lover
    123
    Jacksonville, NC
    Ratings:
    +72 / 9
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Noticed the same on mine, but no loss in performance or towing a skier... I have to assume our AR240 '10-14 models have made the trips to Bimini without issue, so for me I'm ok seeing it rattle at WOT as long as there are no cracks forming in the fiberglass.
    • Like Like x 1
Share This Page
