Basic maintenance class
Hilldale
I purchased a new Yamaha 2017 242 S limited this season. I would like to do my own basic maintenance - similar to what I can do on my cars - oil, plugs, tire rotation, etc...... and at least be able to do some basic troubleshooting when needed. Anyone aware of any basic maintenance classes to get me up to speed? I am at Lake Wallenpaupack in Northeast PA.
Thanks
There a a ton of "online tutorials" here. Check the FAQ. Also, check out the user map. Chances are an experienced owner is close by and would be happy to help you "learn the ropes".
Plenty of videos on you tube as well just please DO NOT use this guys method.
Wow. Just... wow.
I suppose he will not have to further lube his bilge any time soon. :rolleyes:
A little 409 will clean up that bilge.
I believe @Bill D offers a course. Just costs a dinner at a bbq joint!
WOW. That's one way to do it.
He does have a good point about not wanting to overheat the oil pump by dry cranking the engine for more that 15 sec at a time. Just as long as you can forget about the crank bearings, rings, cams, shims, timing chain, etc. being run dry ;)
Thanks. There are certainly a number of online videos. I never took an online class, but, there's first time for everything.
Thanks.
The one thing that is pushing me to take a class or at least learn some of the basics is that in Northeast Pa, there are no JetBoat dealers. I am worried about having a typical Prop Shop do maintenance on my Jet Boat.
Find a dealer who sells and services Yamaha wave runners. They will have the knowledge to do all the work from my experience. However they cannot do warranty work.
Thanks
I was in your position last year when I purchased my boat. Best thing is to go through the forum for every maintenance you want to do. You have tons of videos and helpful suggestions. I can now do basic maintenance on my boat. I am sure you will too. Good luck.
Damn I just Rick rolled myself
When he started walking back with the bucket. I was damn it not again
