Battery tending off the boat
Wesley Cobb
After a quick search on battery tenders, I see I need one for this winter. I dry store my boat on the top shelf so no shore power available. I want to remove the batteries, store them at home and hook them up to a tender mounted on the wall of my garage.
Any issues with (1) keeping the boat off power for several months and (2) tending the batteries at home? I know I will need to keep them off the concrete floor and as warm as possible. I am most likely going with a NOCO or ProMariner 8-amp tender on my 2017 242 s e-series.
Mike Clark
Germantown, ohio
I also remove my batteries for Winter. Leave them in my garage, not heated, but insulated, never gets colder than about 40 degrees in winter. (in ohio, so not real far north)
I do not have a battery tender, but do have a smart charger. I usually charge mine up after taking them out out, then do a quick voltage check every 2 months to determine if I need to hook back up to charger. They tend to hold a pretty solid charge all winter. This of course probably all depends on how old your batteries are to start with.
Never had any issues when hooking them back up all, electronics, connext, etc, all worked fine.
Dave burke
Near Lake Placid
I store mine in my garage (on a 2x6 plank, not right on the concrete). it’s unheated but attached to the house so it probably doesn’t get much below freezing. I use A Promariner 12A two-battery charger that I bought last year.
Dennis P
Montreal, Quebec, Canada
Limited
Batteries out , in my heated basement, put the smart charger on them every 60 days, 3 years now all good!
jsg73
Lake Cumberland
A charged battery will not freeze. Mine stay in the boat in an unheated barn all winter and can stay below freezing for days but each does have a Battery Tender Junior attached.
paragus
Not storing batteries on concrete is for old batteries when the glass cells were enclosed in a wooden box. Modern batteries are made with plastic or rubber and it doesn't matter stored on concrete or not.
Joshua Miller
Jacksonville, NC
252XE
Just make sure you take a picture of the positive and negative lead hookups before you disconnect. Every spring you see posts from boaters who re-connected their wires wrong.
jsg73
Lake Cumberland
Or make a sketch of the connections and leave it in the boat.
grywlfbg
NE Oklahoma
All good advice here. I think you could 2 battery tender jr's for less than the cost of a dual battery tender. And as @jsg73 said, if the batteries are fully charged they won't freeze. So if they're on the tender they'll be fine wherever they are.
Wesley Cobb
EXCELLENT advice! I have pictures already from the earlier this year when I had to replace a battery. Thanks for the reminder!
Wesley Cobb
Thanks for all the advice and information. As a new boat owner (when do I no longer get to say that?) and worrier, sometimes it is good for me to just read shared experiences. I never grew up with boats so I am learning as I go along. This forum has been wonderful!
I purchased a dual tender and will get the batteries out of the boat this weekend. I will build a shelf and hang my tender as well just to free up floor space in my garage. Again, appreciate all the advice.
Matt Phillips
Lake Tahoe
I use a dual battery tender in an unheated garage (only barely drops to freezing occasionally). 4 years on the batteries and no issues.
Renod
Grosse Ile, MI
I bring 'em in, put them on a shelf in the basement and hook them to a Dual Output Battery Tender. I leave them plugged in to the Tender all winter long. Never had a problem with any of the batteries I hooked up to a Battery Tender product. This includes boat batteries, a half dozen different Jet Skis over the years and a 2013 Jeep.
Wesley Cobb
Great! Thanks for the words. The set up you describe is my project for this weekend. I am building a shelf for my two batteries and mounting the tender to the wall.
