Bearing buddy dust cover lost
Hezi
Secaucus NJ
212S
I lost one of my Bearing Buddy dust cover. I guessed it popped while driving with the boat few miles. West Marine 3 options ended up being too small or too big. I ended up taking a plastic sheet folded on 6, Gorilla taped it to the hub, and clamped it with radiator clamp. It did the work for this weekend but for the life of me, I can't find a replacement on line.
I measured the Bearing Buddy that came with the boat trailer to be 2.125" in diameter. Does anyone had this before?
Can you help point out to the right cover online? I am going to clamp them all now. Can't have this happening again.
Thanks!
swatski
North Caldwell, NJ
Thanks!
I think you can get those at Menards or Walmart! Not expensive.
Cobra Jet Steering LLC
Vendor
Florida
Bad sign, jack up the trailer and inspect the bearings this is the first thing that happens when a bearing is about to fail. maybe you will be lucky but I hate seeing one missing because it is usually a warning sign
zipper
Boston Whaler
Did you lose one on a rear wheel? I lost a bra a while back due to a stuck caliper heating up the hub and throwing the grease out and the indicator pushed the bra off. This was my temp. fix until I replaced the caliper and the bearing buddy. So yes, there is an unseen reason for losing a bra.
