That is the exact one I put in my 242 locker. Folks should keep in mind, that this one is nearly the exact dimension. But whatever you put in there, you only fill it to the size you need. So if you need something else in there, you don't fill it as much. Or if the bag is too big or too small, it will conform to the space.W707 Fatsac..... I sell them everyday for the ski locker.
I don't know your prior boat history but personally I wouldn't want to carry 1000 pounds of lead in my boat ( Yamaha ) all the time. I have 200 lbs of lead in our boat and I hate moving it around when we surf and then change for everyday cruising. 1000-1500 pounds of lead in an inboard is a completely different story. They have the power, traction, and tabs to counter act that much weight. You will defiantly be getting a work out moving those things around and so will the gas pump.I have my ballast. Went with sumo max sacs since I like their pumps better due to speed and ease of draining. 1000lbs of lead weight (20 -50lb) for swim deck seats. Plan to put 800 in center and 209 to move back and forth to switch list for goofy/regular. Also have one 450 sac and one 575. Will move around depending on many people in the boat. The lead weight bags give alot of flexibility to move the configuration around.
I actually looked at that bag but the locker is only 16" wide and if I remember 19" deep. I didn't want to put pressure on the side walls and lose all that storage, but hey if it works then great! I will give that or the Sumo a try if the W730 doesn't work out.That is the exact one I put in my 242 locker. Folks should keep in mind, that this one is nearly the exact dimension. But whatever you put in there, you only fill it to the size you need. So if you need something else in there, you don't fill it as much. Or if the bag is too big or too small, it will conform to the space.
This one just happens to be about perfect. Heck, I fill them with air first to be sure it is sitting right before filling. As you are not going to move it once it's half full. Good luck!
I think that's the whole point, more weight equates to more mass. If you want more than 400lbs etc, you have to use more water, which takes more space. Unless you go to something more dense, like lead. The whole point of water, is you only put in what you need, and the days you don't need the space, you go to full.I actually looked at that bag but the locker is only 16" wide and if I remember 19" deep. I didn't want to put pressure on the side walls and lose all that storage, but hey if it works then great! I will give that or the Sumo a try if the W730 doesn't work out.
