jetboater4life
- Rochester, MN 55901
- X
I'll be installing my kit soon, and had a couple of questions that will hopefully prevent me from running to the store for parts multiple times.
I have two group 24 AGM batterys and a pulsetech dual bank charger.
In the blue seas diagram below do I need to be concerned about the start isolation wire? What size/type of fuse should I use between the battery positive terminal and the ACR?
In Mel's diagram below, I'll be installing a ground bus as well as a light for the dash. I need to install my ACR to the load side to allow my batteries to be isolated when the boat is stored. This allows the dual charger to work it's magic on each battery independently. Are there any drawbacks to doing this or anything I need to consider that would cause the system to behave adversely in this configuration?
The blues seas diagram.
And Mel's diagram.
And Mel's diagram.
