- Royal, AR
- SX
Tonight I pulled up to the ramp and my wife took the helm as I went to get the trailer. She quickly asked if the engines should be smoking and then pointed out that one of the tachs had the red overheat light on. The ramp we used today was in the end of a cove and the lake was full of debris cut up by the holiday traffic. While pulling up to the ramp some debris caught in one of the reverse buckets. I had to cycle from forward to reverse several times before it shifted freely.
She turned off the engines and we discussed what to do. She restarted the engines to counter the backwards movement and saw overheat lights on both engines.
After I backed the trailer down the ramp she started the engines again and only the port side had an overheat light. After pulling the boat out of the water I noticed pieces of trash bag sticking out of the port jet intake. Looking in the jets from behind the port pump has a 1/4" stick in it as well. We checked under the engine hatch and did not see anything unusual.
I am hoping that I simultaneously sucked debris into both of the jets blocking cooling water intake to both engines. I will clean out the jets tomorrow and see how they run.
I would really appreciate your advice.
