Bought OEM SX240 mooring cover, what am I doing wrong?
Patriot
Massachusetts
I got 3 years out of the shipping cover for winter storage which seemed OK for free. I just picked up a Yamaha Deluxe Premium OEM mooring cover MAR-242NT-BK-15. Appears this is the latest model for the SX240 because it has the cutouts for the bimini top unlike the one I thought I was ordering that is pictured without cutouts. I would have preferred no cutouts since its just winter storage and the bimini is off so now I'll have to block the cutouts. The bigger issue is that with 2 people helping I can barely get this cover over the rear rub rail with the rachet straps as loose as they will go. Anyone have this issue or an idea as to what I'm doing wrong. I'm open to suggestions :)
AJack
Tampa 33621
If that's the grey cover, it's the same one I have on my 2018. try loosening the side straps (not the ratchet straps, but the one under the velcro cover) a bit to make it go over the rear rub rail.
If you find a way to block the cutouts, let me know.
Patriot
Massachusetts
It’s the black one. Should be the same. I didn’t see any additional slack in the side straps either. 2 on each side. If I undo those to get the stern on then there’s no way I can reconnect the straps. I’m perplexed.
djetok
Edmond, ok
Mine was very tight , and gets very tight if I don't put it on for a while. If that's the issue. It does stretch.
Gary Tait
Tallahassee, FL
I have to clip both sides together, then muscle the cover over the stern lip. It's gotten easier over time, but definitely had me scratching my head at first.
Patriot
Massachusetts
Thanks for the responses. The instructions say after cover is on to ratchet strap it 4-5 times. It's so tight I can't ratchet it at all. Hopefully it stretches out over time. Makes me long for the shipping cover again. That was a breeze and you could sock it up tight with the ratchet.
