Bow Rail Loose
MontereyJake
Traverse City, Michigan
2008 SX 230.
Starboard bow rail is loose on forward end. It moves maybe 1/4" side to side. Icebox is under seat on that side. Does anyone know how that is attached (screw or nut) ? How do I gain access to the inside to tighten it?
96Pirate
Wake Forest, NC 27587
I have the same issue on my ‘07 and keep putting it off. I assumed I would need to access from under the small bow seat. I am not sure my arms are long enough though
F.M.
Decatur, AL
I just tightened mine on a newer 242. It was nuts on the inside. 14mm I think. Don't know if it's the same on yours though.
Rich Lynn
See if you can access it from under the front cushion
Scottintexas
Corinth, TX (DFW)
Check the nut size on the other side and get a long extension
Zonie
Rotterdam Junction, NY
I got to mine by crawling under the helm and using a long extension. Wasn't easy but it worked.
sethman919
Apex, NC
Might be easiest to just pull a speaker and go through a speaker hole.
Beachbummer
Houston TX
Pull the speaker and the nut will be within reach.
Wear long sleeve to keep the fiberglass off your arm, not like I did when I was in there.
Erik Begg
Limited
I went through the horn. Just unscrew it and pull it out. Forward end of starboard bow rail is right there.
