Brake Shoes
Mystic1906
Lockhart, FL 32810
Brakes started squealing on my 2016 F150 XLT. Need to change the pads. Went to AutoZone (Duralast Premium Gold) but they have ceramic pads. Heard they aren't good for towing. Looking for recommendations on brake pads as I know y'all have faced this prob many times.
Redneck_4Play
CONNECTICUT
I've had bad luck with both Autozone Duralast and AdvanceAuto Everwear. Even their "gold" pads wear quickly and don't last. Personally Raybestos, Wagner, ACDelco are worth the extra few bucks. Just my 2 cents.
Trannyguy
Sw missouri
Hey I own a shop in farm country and 90 percent of what we work on are trucks that mainly are used for towing and we have very good luck with c-max pads from autozone. We also maintain all of the county sheriffs cars and use them on them as well and they all love them with very little complaints.
Seadeals
Greenville, South Carolina
I run Hawk pads on my 150 and am very pleased. Be sure to inspect the pad thickness. The squeal might not be the wear warning, you may just need to clean and re-grease the piston/pad contact area. Also, be sure to wear in the new pads if you go that route. It is a fun drive on a back country road.
Liveto99
New York Hudson Valley
I have a bunch of trucks, about 20. I have found the best brake pads are the OEM ones. I just get the most miles out of them, I use aftermarket rotors if needed but OEM pads. On Fords I change the pads at 50k that way I don’t have to do the rotors. On the Nissans I do it at 70k same reason. We also change the front and back at the same time the backs only last a little longer. 200k out of a truck, 2 changes on the Nissan and 3 changes on a ford. I only get 15 to 40k out of any aftermarket pad I have tried. FYI this is vans not pickups.
