Brand new 2020 212X - Ski & Tubing Questions
ScrewWorkn
Just dropped my new 212X in the water last Friday. Got up on 2 skis first try, last try before that was 27 years ago or so. Didn't last long because there are some muscles that need attention, but love the boat.
Question:
1. For skiing I should be on empty ballast right? Ever a reason to add some?
2. How long of a rope are you using for skiing on the jet boat. Not sure what I used (borrowed from a neighbor) but the wake was turbulent. Thought moving back a little might help.
2. We are going to be doing a lot of tubing. I would like to get a dual rope, any recommendations? I see a bunch that say you need a 12 foot wide boat?
3. Again what length rope you using? The riders were getting some spray in their face.
Thanks guys, I'm I'll have more questions.
jsg73
Lake Cumberland
If I recall correctly the ski rope is 75 feet. Some put a 15 foot extension on it. I just stay outside the wake most of the time.
I do not put in any ballast when skiing or tubing.
For tubing, I suggest you buy some swim goggles. Cheap and easy solution.
biffdotorg
Pelican Rapids, MN
Biggest difference in ropes, is that for tubing or any towable, having it as long as it takes to get out of the spray. But the tube rope is many times thicker and has some stretch to it. It takes some shock out of the tow when getting going.
A tow rope for skiing and more specifically wakeboarding will be the length needed to get in the sweet spot, and that will be different for skiing over boarding. That and the rope will be a thin, no-stretch type. These ropes are like a synthetic winch cable almost, but thinner.
The handle on a ski rope may be narrower, but that isn't as important as a wakeboarder will want a wider padded handle, as they many times pass the handle often, if not behind their back.
When I say sweet spot, a skier wants a flat wake (no ballast) as they are crossing the wake with minimal air and usually at higher speeds. A wakeboarder wants that rope to put them in at the ramp of the wave. In other words, we are looking for air, and ballast gives us that volume. The rop puts us on the ramp. This is why all the best ropes have removable sections to tune the rope for the wave each time out.
Good luck!
PS: If you start surfing, buy a surf rope when possible. Yes you can shorten a ski rope and use it to get by. But a surf rope will have easy length adjustment at shorter lengths, will have grab handles every so many feet for the surfer to pull into the pocket. And the handle will be heavily padded. This is for the safety of the spectators in the back of the boat. There will always be that time that the rope will fly back at the boat as the surfer loses grip.
