Sidewinder
- Simcoe Ontario Canada
- Scarab
- 195 ID
Does anyone have information on break in period for rotax 250Hp on 195ID
It should do that, yes, but just in-case...From my understanding, during the break-in period the throttle is limited automatically. RPM is limited until the break in period is over and it 'kicks in' after the break in period is done.
10 hours to full break-in is correct...however:Should be 10 hours. I'd (try to) keep it under 5,000 RPMs before going WOT.
What problem are you referring to?The windshield seems to be a problem. I will inspect that when I pick it up and look too beef it up.
Thanks for the info Nexus. By any chance is anyone else having issues with it loading? I tried to go to the page under AH and then to 300 motors and it shows a blank screen.You will find the break-in period in the owner's manual when you get your boat. If you can't wait, then check out www.operatorsguides.brp.com , select "Rotax JPS" and then choose your engine.
*Edit*
It should be under "AH" as that seems to be the newest engines.
It works for me. I'm using a Chrome browser on Windows. Not sure if that makes a difference or not. Once you click on 300, there should be an "Operator's Guide (EN)" link below. I think that all four engine types (150,200,250,300) all link to the same manual.Thanks for the info Nexus. By any chance is anyone else having issues with it loading? I tried to go to the page under AH and then to 300 motors and it shows a blank screen.
