Can I change my oil filter without extracting oil
Lpennington
Raleigh, NC
I had to change my oil before a week long trip to the lake last month. I couldn't get the filter off so that didn't get replaced, only the oil. Can I change the oil filter without extracting the oil ... if I can, will there be a bigger mess as a result?
Cobra Jet Steering LLC
Vendor
Florida
Sure you can just place some newspaper or rags under it but that is necessary in any event when you remove the oil filter you do drip some oil , and be sure to add a bit of oil to replace what was in the filter.
Vendor
Florida
Get a huge pair of 16 inch channel locks I call them the oil filter persuader never met a filter I could not remove with those.
Lpennington
Raleigh, NC
Jeff, are saying those are better than a plain oil filter wrench?
Vendor
Florida
for removing a filter hell yes been doing that for over 50 years my channel locks have never failed me when it comes to a stuck oil filter but NEVER use any wrench installing a filter I like the Fram TG3600 oil filters they have a rough gripping surface at the end for tightening them with your hand. And the case is very heavy duty the filter has a 99 percent efficiency rating and more capacity than the factory filter and not expensive average price is in the 6 dollar range
