  • Gantlin Products, the creator of the WAKE WEDGE is currently running a Group Buy for those of you that want a better, cleaner wake to surf behind your Jetboat! This Group Buy expires on April 1st, so get your order in ASAP to jump on this once a year discount on the Wake Wedge. The discount could go as high as 15% off!
    (You can click the X in the upper right to dismiss this notice)
Chapter 3 - CONNEXT "ERR" Message
captras
Ratings
670 30
Lake Livingston, Texas
Well, for the third time now, my connext system is screwed up. Once again, the GPS is losing signal which results in an ERR message on my speed. This, in turn, causes the engines to momentarily throttle down when in the DRIVE mode. Once again, this feature, that Yamaha says is so great, is unuseable because the GPS connection is unreliable. Dealer has been contacted, but I am not going to take my boat out of the water for the rest of the season while Yamaha tries, once again, to figure this out. It worked fine for about 5-8 hours, then began the same issues as in the past 2 events. Seems like from new, to the first failure, to the second failure, then to this last failure, it takes about 5-10 hours for the system to begin to fail. Fortunately, I can do without this feature for the rest of the season! But Yamaha needs to get its deffication in an orderly sequence (get its S**t together) and resolve these CONNEXT issues!
Ratings
I have the exact same issue. Took it in and dealer of course said 'We can't duplicate it, must be GPS interference." I'm like, Interference in the Middle of a Lake? I now have this video to show them, plus I'm going to show them this thread. Hopefully, they will fix it. I just bought the boat 4 months ago. If you listen close, you'll hear the engine cut out when the display goes to Err.
fraserjr
Ratings
187 2
Fairfax, VA
Did anyone ever find a resolution to this issue? I don't use drive control or cruise control much but would still like to address this issue if we have discovered the root cause and how to solve it.
captras
Ratings
670 30
Dealer finally fixed mine. Changed module, GPS antenna, and found loose connections. So far it has worked perfectly! Fingers crossed. It took 3 times to get it fixed right!
fraserjr
Ratings
187 2
Fairfax, VA
Where did they find the loose connections? I will have to check mine before I try and send it to the dealer. Hopefully it's a simple fix.
captras
Ratings
670 30
During the 3 trips to the dealer they found lose connections at the antenna and the module. The also replaced both the antenna and the module. The last connection they found loose was somewhere in the engine compartment, but I will have to check the invoice next time I have the boat out. I believe it had something to do with the RPM sensor, but not sure! Sorry. ..I know this probably didn't help much! I will say that since my last service, the Drive control has worked perfectly everytime, so there is hope. Has alot to do with the dealer taking responsibility and not dismissing your issue just because it is intermittent and not manifest itself when they check it one time!
fraserjr
Ratings
187 2
Fairfax, VA
Sounds like I have some connections to check.
Brad Dunn
Ratings
37 1
British Columbia
I have this same issue, Yamaha said it is in the gages, I sent them for recalibration under warranty. I sure hope this works. Probable be a few weeks before I get to try it.
