Chart Plotter Placement on newer boats with connext? Simrad Go7 installed
Benny Sibbitt
Winter Garden, FL
I know this have been discussed and discussed but having a hard time finding info and photos of gps placement on newer 24 ft boats.
Where and how are you guys mounting chart plotters on your Boats with yamaha connext screens?
5 or 7 inch screens?
Thinking of simrad go5 or go7?
Love the 7 inch screen, just don't know where to mount it or if I have room?
Thanks
Neutron
New Bern, NC
Here is where i installed my G07. I made a mount out of starbord, painted the starbord black and undermounted it to the side where only the shape of the base of the ram mount was showing. It was a clean look
Benny Sibbitt
Winter Garden, FL
@Neutron that looks good! You have a closer shot of the mount?
Thanks
Neutron
New Bern, NC
If i get home early enough i will get a new pic of the mount close up
Benny Sibbitt
Winter Garden, FL
@Neutron did you install a transducer with this unit?
Neutron
New Bern, NC
Yup. The Totalscan ducer
Neutron
New Bern, NC
Here is pics of my ducer mount
Had to shim one side to compensate for the angle forward
Benny Sibbitt
Winter Garden, FL
@Neutron clever....great idea running the wires out of sight....
the 7" doesn't look as big as thought it would... I was concerned it would over take the helm.
swatski
North Caldwell, NJ
Neutron
New Bern, NC
I was concerned it wouldbe in the way but it is out of view and doesnt hinder access to the touch screen, mouse, or throttles
MrMoose
Calgary, AB, Canada
I'm using a RAM mount just forward of the throttle levers. The cable is recessed just above the RAM mount. I use a 5" Garmin for the Bimini trips, but I don't need a GPS on my home lake. It's easy to install and remove. When it's removed, it's hard to tell that it was there in the first place.
BigAbe75
Litchfield, IL
In case it's an issue, I think that's the same little nook where the @JetBoatPilot Perfect Pass mounts if you get their mounting bracket for the newer models.
Edit: to include product link here
swatski
North Caldwell, NJ
For anyone planning on installing the PerfectPass, keep in mind in Connext boats the controller goes into that space ahead of the throttles:
Also, in conjunction with transom transducer install, I would consider whether or not trim tabs will be desired. There are many options, we are about to start testing one tab set designed with Lectrotab spanning 16" of transom between the ride plate and the outer chine.
EDIT: I guess @BigAbe75 noticed that too, LOL.
Neutron
New Bern, NC
I see your points but for me they are both non issues. Have no intentions or needs for either.
My gps mount could still be moved back without interference with throttles to clear that perfectpass gauge
Benny Sibbitt
Winter Garden, FL
@MrMoose the red connector, is that a fixed extension for your plotter wires?
MrMoose
Calgary, AB, Canada
The red plug connects to the back of the plotter. It pulls out to connect to the plotter, and slides back in when I'm not using the plotter. I'll take a pic of the plotter installed tomorrow.
MrMoose
Calgary, AB, Canada
IMG_20170202_105006946.jpg IMG_20170202_104937424.jpg IMG_20170202_104920618.jpg
Neutron
New Bern, NC
Looks great... very clean install
