Check Engine Light Flashing
JBRyan
NE AL
Just bought the boat from a individual and had no issues on my test drive. My starboard check engine light is flashing a pattern of 1 flash then pause then 9 flashes then pause and it starts over again. No loss of power, seen water coming from the side holes. I can use no wake mode. No other lights were flashing. Any idea what it might be or what to check before taking it to a dealer?
Gym
Falmouth, MA (Cape Cod)
@JBRyan here are the check engine codes for our model boats. They can also be found in our FAQ section.
  1. 01 No malfunction
    13 Incorrect pickup coil signal
    15 Incorrect engine temp sensor signal
    18 Incorrect throttle position sensor signal
    19 Incorrect battery voltage
    23 Incorrect intake air temperature sensor signal
    24 Incorrect cam position sensor signal
    29 Incorrect intake air pressure sensor signal
    48 Incorrect data transmission
    54 Incorrect bypass valve motor signal
