Robb235
- Chattanooga, TN
- Other
If the ECU detects a fault (bad engine temp sensor, for example), does the engine have to actually be running in order for the Check Engine Light to flash on the tachometer? Or can engine be off, but the key on in order for the CEL to flash the fault code?
