Jubin Payandeh
- Thunder Bay
- 255XE
I have a 2014 195 HO Impulse with 68 hours.
At the end of last season, was running fine. Had it winterized at the local SeaDoo dealer.
First test start in driveway - low oil pressure error.
2nd test start - fine.
Into the water - starts fine, will only rev to under 6000. Check engine light comes on.
At one point it flashed a fault code of P0106.
I tried restarting, resetting etc. No luck.
It will run but the revs are limited to under 6k. All the fun happens over 7K!
Any advice short of taking it back to the service center?
Thanks,
Jubin.
Thanks,
Jubin.
