jgiovino
- Melbourne FLorida
- Glastron
- GTS
I have a strange problem and out of ideas.
2014 glastron 207
rotax 250
31.4 hours
Yesterday
Ran the battery down after sitting with battery switch 'on' for a couple months.
No start with trickle charger.
replaced battery with blue top marine optima
Everything is great, runs fine no problems.
turned on and off numerous times out on the water.
When I went to flush boat it did not start, did not crank.
After a minute it fired up like nothing had happened
flushed and buttoned up.
Today
boat started no problems at all
pulled out of dock and shut down about a minute later
picked up my kids, fired up again no problem.
Shut down about 2 minutes later to drop tube and kids in water
No start, no cranking, just a "check engine" on the gauge.
pushed boat back to dock, luckily i didn't drive too far before dropping kids in.
I tested neutral safety switch, safety harness kill switch, ignition voltage.
all fine. 'bumped' the starter relay and it cranks too.
Don't know where oil sender is but would expect that to throw a code.
Also, no codes on gauge cluster, not sure if that means anything on my boat, however.
Any and all ideas are appreciated.
Thank you.
2014 glastron 207
rotax 250
31.4 hours
Yesterday
Today
Thank you.
