WildCatFan54
- Lexington , Ky.
- 242 Limited S E-Series
Today , after uncovering the boat , turning on the main switch for house and starting battery , then putting key in the ignition , Connex came up to the start up screen as usual (see attached) . Normally after a few seconds the bilge and blower kick on and the screen goes into "Float" mode. Not today ? 5 minutes later and still on the splash screen. I started both engines , no problem but still no Connex ? I switched the key off and turned off both main switches and waited 15 minutes. Repeated the same process that I have done hundreds of times. Still no Connex boot up ? Both the bilge and blower are working per normal. I suspected low voltage on the batteries so put a multi meter on both. 13.1 on house battery and 13.3 on starting battery so NOT low voltage. Guess I will be calling dealer first thing tomorrow AM unless there are some suggestions from another late model E series owner ? thanks
