Connext screen error
Oscar0421
Simpsonville, SC
My 2018 AR210 had error on the connext screen and didnt show the mph. The dealership said has a code of electronic throttle valve. Today the dealership contacted me and said that Yamaha is thinking its going to be the throttle bodies. Has anyone had this issue? If so, what was done to repair?
Oscar0421
Simpsonville, SC
Dealership called me saying its the transducer and that its on back order until October. UGH! Told me I can use the boat just fine even though I cant read the mph.
Shall2020
212X
Had the same issue plus navigivation didn't work on 2020 212X. Changed the antenna and works fine now.
David gram
Just dropped my 2020 ar240 off at dealership due to system communication errors and CAN System errors. Tach shows ERR on Connext display for both engines and the Cruise/wake mode buttons on joystick do not work. Will update post once I receive response back from the dealer on what the issues are.
212s
1000 Islands
212S
Please keep us updated - good info helps everyone.
:thumbsup:
David gram
Update from dealer. They replaced air intake sensor and did not resolve problem. Dealer had to reach out to Yamaha as they could not figure out the communication issues and can. Error issue. The service manager called me and said they are waiting on Yamaha technician to get back to them about the wiring harness. The dealer has also requested a field rep to come out. Very strange, bought new 2020 Yamaha ar240.
Doogie55
Did you find out the problem?
