I have a 2007 SX230, is water supposed to come out of both ports on the drivers side of the boat when both engines are running,? Haven’t had any overheating, just wanted to be sure... thanks
Once a thermostat opens one of the pilots toward the stern streams a little a low rpm. The front two pilots depend on higher rpms from exhaust gases. Those you check out on the water.
