latitudeadjuster
- Mineral, Virginia
- X
This is a culprit for many intermittent engine non starting and stalling issues. "The boat started fine, when we stopped it wouldn't start. I waited 5 minutes and it started." A few times later it happened again. No codes dealer couldn't trouble shoot because it just wasn't happening. The mechanics open up the fuel tanks and find this little piece of aluminum or paper seal.
Be sure to TOTALLY remove the foil or paper seal. These containers sit a long time before use and in cold and heat sheds or garages. You are in a hurry stop and buy some treatment pop the aluminum with your car key dump the treatment in your ride and threw away the bottle.....never noticing that the foil or paper seal came off in your filler fuel neck.
Hard lessons learned with this so I just wanted to pass it on since I was adding some treatment!
