2kwik4u
- Georgetown, IN
I'll admit, I've been doing this for years. I've just recently been spurred to think about the actual effects of this, and why it's a bad idea.
Backstory, I'm working on some analysis work for a piece of vibratory equipment that is suspended by steel cables. This machine operates around 500rpm or so (9 hertz), and weighs around 80k lbs with product included. It hangs from (4) wire ropes that are secured with pin connections at each end. Customer replaced the pins with bolts, and then cables failed. So I get to analyze the failure, write a knowledge base article, and ultimately do root cause analysis on the failure. We use cables to suspend a good deal of equipment and it's rarely an issue, so I was sitting here thinking about the failure mode, and how the cable was being loaded outside of it's intended direction.
That got me to thinking about how I twist the chains on my trailer to keep them shorter and off the ground. The chains are FAR to long for the hitch setup I have, and I've just twisted them up a bit to make them shorter. It's worked fine for keeping them off the ground and not "clinking about", however I had never put much thought into the loading on the chains should then be called to action. So I went off researching and found this great article.
They talk about twisting chains, how and why it's a bad idea, and how the loading differs between a straight chain and a twisted chain. That article also links to the below video that is a pretty good example of the decreased strength of the chain.
Here's what my current hitch setup looks like. You can see there is significant amounts of twist in the chain to keep it shortened and off the ground. I'll be redoing this setup the next time I have everything hooked together. No reason not to, as it's a simple remove a bolt and shorten up the chain available for latching.
I'm curious. Anyone else twist chains like this to shorten them?
The Low-Down On Twisting Safety Chains - From The Mechanic's Post
Should you twist a trailer safety chain to make is shorter? Here is the Engineering on why twisting safety chains is a bad idea.
mechanicalelements.com
