blacksapphirez
- Charleston, SC
- SX195
Was not going to buy a chartplotter then went to full 7 inch with Navionics... funny how that happened
Followed some of the advice given here running the cable through the scupper hose and it is a great idea. NO DRILLING! and popped right out in the engine bay which then I routed to the helm. I cut the scupper drain hose at the rear of the engine in a square and filled it back with 3M 4200. The wire harness is like 2 inches too short. so I had to purchase(on the way) a transducer cable extension. I need 2 inches and they come in 12 feet! whatever. I can tuck the wires away from the floor at least.
For the mounting, I used the Ram mount, at the upper most "flat" area on above the throttle. I pretty much shoved it there ... it does have some limitations on movement however, I don't see myself moving the display in other ways. I pulled the cable behind the gauges. does have some room for the cable to come through so again NO drilling there. When not in use, cable will tuck between the opening "the crack" Don't remind me about the 4th screw...long story
Not sure if the transducer mounting is the best place. Since I wanted to run the cable through the scupper, it was the ideal place for me. Didn't want to run cable across the back of the hull and wanted to clear the exhaust.
