Solraider
- Brainerd, MN
- Scarab
- HO Impulse
Sharing this because I have not heard of this happening on this forum.
Murphy's Law at its finest. We are very careful-cautious with our boat, meaning nothing gets wrapped/into the impeller, no rocks, no ropes, no fishing line etc.. Its a 2018 195 250 HP with 58 hours on it. It can be docked several hours and not a drop of water seeps in. After overcoming the initial quality issues last year that have been covered on this forum we thought we had a problem proof boat.
This past Saturday while boating we were running about 5000 rpm when the boat slowed down and RPMs went up amidst a loud rumbling rattling noise from the pump area, we shut it down immediately. On the boat lift I inspected the intake, fixed shaft, impeller, and wear ring with a small mirror and headlamp. They all looked free of issues like nothing ever happened. So then I thought (based on another members issue with finding a small sliver of wood between the impeller and wear ring) that I might have the same issue. With boat in garage I removed the pump. As soon as the four nuts were loosened on the impeller pump housing the housing tipped ever so slightly down - which it should not because the spline shaft and impeller boot should support the pump more then what I saw happen. I took the pump off and set it aside. The impeller boot stayed on the shaft which is wrong, it is supposed to be threaded into the impeller and slide out with the impeller. The pink arrow on the boot photo points to the threads meant for the impeller.
What was the cause? Based on the mechanics evaluation (and I agree with him) the impeller boot was never installed correctly onto the impeller which allowed water to get into the spline mating area, effecting the grease that was in there etc. Over the winter the water that was in there froze and may have expanded the impeller hub. There is a slight crack on the inside hub in the photo. This all lead to the spline wearing and then slipping inside the impeller.
My dealer is 2-1/2 hours away and that's where the boat is now. I like my dealer, they have been responsive to issues. I don't foresee issues in getting this done in a timely manner. Will see how it goes and how Scarab covers this.
Murphy - we still love the boat.
