props2you
- Round Lake, IL.
- 242 Limited S E-Series
Seems to be @swatski is the resident Ribbon Delete aficionado, I divert some questions...
Has anyone done the delete on the E-Series? Started to dive into it but seems a bit more complicated and than other models. Yamaha has put everything inline on the E-Series (see pics) and reduced the amount of room to remove parts. Can't even take the airbox off unless I get a wrench on the backside of the bolt in the fuel tank compartment. (the nut on the airbox just spins and spins) I realize 2 bolt on and 2 slide in the rubber grommet, but it's a PIA to get the 2 undone.
Seems like a lot of work for 200 RPM...
Any tips or suggestions??
