Engine wont run
Darryl
Last time I had my boat out the starboard engine shut off.. since then I have checked the lanyard switch the hatch switches replaced both ignition switches and bought yds software...
The yds works great on the the engine that runs.. wont communicate with the engine that doesn't run.. does me no good.. any suggestions?
2005 sx230 Yamaha
PaulyB
Bumpass, VA
You are bumping the bad motor over to establish the connection?
Darryl
Yes .. I was turning the motor over while my son was on the computer
itsdgm
That’s a bummer. Can you describe exactly what it will or won’t do? Is it cranking, but not firing, etc.
Darryl
No fire ... getting fuel but no ignition
Seadeals
Greenville, South Carolina
Are you getting the “hum” of the ECM when you turn the ignition on? The hum usually stays on as long as the YDS is hooked up and “connected”. Since it is not reading, seems to indicate an issue with the ECM and you can compare sound with other engine since it will read that one.
PaulyB
Bumpass, VA
Maybe swap ECUs? It sounds like it may have gone bad, but that would be strange.
Marvin willis
Morehead city nc
Mine went bad last year. Wouldn’t get fuel. Swapped to confirm. For something so small that ecm is expensive
Gym
Falmouth, MA (Cape Cod)
Possible blown fuse under the round cap on the ecu?
Cobra Jet Steering LLC
Vendor
Florida
Have you cleaned the electrical connections and the main engine ground connection ? Often if you open each connector and spray C R C or similar silicon
into all the connections then put them back together, if any water or moisture is in there this will fix it instantly.
Beachbummer
Houston TX
Hi, this was a while ago... Did you get it sorted out?
