ColaDawg
- South Carolina
- X
Hey guys!
In regards to the drip hitch, i had a 2" that I've always used on the truck. For the boat, I did have to make it a raise in same way you did. I'll agree. It is crazy the height difference in the GM SUVs and our trucks. A new larger drop hitch appears to be in my future.Congrats and welcome!! Awesome boat, we love ours.
1. I usually use a 4” drop hitch on our Tahoe - no air leveling. And I use a 2” raise? (2” drop hitch flipped upside down) on my F250. Seems crazy to me that the Tahoe is taller than the truck.
2. I haven’t done that shelf mod, but really want to. From what I’ve read, you don’t want to make that too snug as the hull will flex going over waves so you’ll want that big open space to able to move as necessary. I’m thinking I would try to rig mine so it has 1/2” room to play somehow and with normal resting have 1/4” gap on either end.
Thanks! I will experiment with this for a while.Welcome aboard, most of us have prematurely hit "post reply" before. No need to now, but you could edit that first post by selecting edit at the bottom of the post. You can change the title or anything in the message. That edit function will time out after a week or so.
I tell her everyday. Thanks. This will be boy #3 (the other two are under 4). I am hopeful that they grow to enjoy the water.Let her know pregnant women are beautiful. Congratulations on the child and the boat.
Thanks for the information. I find it to be an interesting situation here at the moment. The lake we live on is currently down for some work along the other side (some old sewer lines cross under one corner that are being replaced) and it won't be back up until hopefully by Sept. With that I am going to need some type of charger for now. From what you said I'll just unhook my Battery Tender charger from the bike and move it to the boat for the time being. Once it is in the water, my tentative goal is to just make sure that I crank it up and ride a bit once a week or so. However, as with the bike, once life starts to really happen, some things fall by the wayside.Nice boat, and welcome! I’ll address the charger issue, most of us build the charger into the boat, so no matter where you go you can just plug it in with a standard cord. Marine chargers are designed for marine environments, thus the specific charger. If you have a certain type of trickle charger/maintainer you use, you could always wire a plug to your batteries that you’d plug into your charger at home, such as with a Battery Tender or the like. That is, if you are only worried about home charging. My assumption from reading the post is that you aren’t keeping it in the water, so this might be a viable option. If you do, then you’d likely want to go the built in route.
That is pretty much what most do I’d say. I’m strictly on a trailer, so if it sits for more than a few weeks I plug in the charger overnight before the trip.So I assume that once I give up the dream, just mount a marine specific charger into the battery compartment, run electricity to the dock (my next quarantine project), and plug in as needed
This is what I do with my overly simplified single battery setup. Have a cord and tender setup, just have to clip the leads onto the battery.If you have a certain type of trickle charger/maintainer you use, you could always wire a plug to your batteries that you’d plug into your charger at home, such as with a Battery Tender or the like.
This is the first time I have seen this explained in a way that I easily understood!! Thanks for that!Your boat has 2 batteries. A "Start" battery to start the engines and a "House" battery for everything else. You also have a small solar panel in the Bimini cover that is wired directly to the Start battery. It will supply a trickle charge to the Start battery when it's in the sun.
You also have a little gizmo called a DVSR. It is the 4th circle thing where your battery switches are. What this does is bridge the Start and House batteries after the Start battery is fully charged.
This means that if you put battery chargers on both batteries they can fight with each other once the DVSR bridges the connection. You basically have 3 options:
1) If the boat is stored outside, do nothing. Solar Panel will trickle charge the Start battery and then DVSR will bridge to trickle the House battery also. If you have a voltmeter, set it to VDC and check that you are seeing 13V+ on the Start battery when the solar is exposed to sun. Once the Start battery is charged the red LED on the DVSR will turn on and you should see voltage rise on the House battery.
2) If the solar panel will be shaded, you need a battery charger. You can put one on the Start battery and let the DVSR bridge and it will keep both topped up. As long as both batteries are the same age, size, etc this will be fine.
3) If you are OCD and want to charge/maintain the batteries separately, you need the disable the DVSR. You can do this by installing a switch in the tiny black wire running from the DVSR to one of the negative battery terminals. When that wire is broken by the switch the DVSR will not activate. When you unplug the chargers you should switch the DVDSR back on so the House battery can be charged.
