Fire extinguisher in the FSH210
Lakanooky
I wanted to mount my fire extinguisher somewhere, but don't want to trial and error the best location. Where do you all stow/mount yours?
Dixie Highway
Daphne, AL
Dealer mounted mine in battery compartment. Seems fine to me, most likely fire location would be next door in the engine compartment. I wonder what might happen if a battery catches fire though, maybe a second mounted in the changing room would be a good idea.
Tailwaters
St Joseph MI
I've always preferred mine to be out in the open. I have mine mounted on the gunel wall just above the rear floor drain on the starboard side. Out of the way yet easily accessible. I'll see if I have a pic
Liveto99
New York Hudson Valley
Compartment in front of bait well has a 4lb ABC in it. Battery compartment has the 5lb Halotron in it. That way there is one on both sides. I can use the ABC on another boat if needed and not spend $200 helping some one out unless I had to. The Halotron is what is recommended so no caustic dust covering everything when used, also made to discharge in the engine compartment extinguishing Port. 5 ga; pail works also and can double as a bilge pump. In the compartment in front of the bait well that extinguisher is not mounted it is cradled in a extra lifejacket and a few towels.
Lakanooky
Thanks for the great ideas!
Maillis
Holiday, FL
FSH Deluxe
I’m pretty sure the boat comes with stickers next to the two recommended locations. One in the console/changing room and one in the battery compartment.
