Fishfinder install on 2019 and newer ar190/195
marcham
Comox, BC
AR195
I'm curious where one would install a fishfinder on the newer dash with 4" connect display? I'm looking at a Garmin striker plus 4 which has a vertical orientation and I need to leave some room for a Perfectpass next year, which I would probably mount on the right side of the dash in front of the usb outlet.
obrien19
Buffalo
I went with a Simrad 5 go xse. Removed the phone holder, and cut the hole right in the dash for a nice clean flush mount.
Dean P
Florida
Chaparral
VRX
I would mount it here or here. To mount it in front of the throttle you would need RAM Mounts to secure it. Good luck...
Dean P
Florida
Chaparral
VRX
This may not be exactly what you are looking for, but what I have installed.
You look like your in my backyard (Florida). Where are you?
M6cabriolet
I just bought the boat and the one picture was in Miami, Biscayne Point. I drug it all the way back to North Carolina lol
Dean P
Florida
Chaparral
VRX
Wow! Looks like channels where I live. Enjoy your jet boat. They're tons of fun. Good luck and stay safe...
marcham
Comox, BC
AR195
Heck, that's almost big enough to watch Netflix on! Looks great.
How did u mount the base to the dash? Self taping screws? Did you need to use a backing plate?
Dean P
Florida
Chaparral
VRX
That's what I'm leaning towards. RAM mount ahead of the throttle.
Those RAM Mounts are so versatile; tons of options. Wish I knew about them a long time ago. :)
marcham
Comox, BC
AR195
Thanks for all the suggestions. I finally worked up the courage to drill 4 more holes in my new boat.
I mounted the RAM ball ahead of the throttle with a matching RAM backing plate on the backside instead of washers and nyloks (easier to reach with a large metal piece than small nuts and washers). The backing plate is threaded.
RAM also makes a ball which matches the Garmin baseplate.
This setup gives me options. I can later on move the fishfinder or add another device half way up the medium arm.
The cables I was able to fit through a small gap between the dash and the black glare screen by loosening the glare screen bolts. Power is pulled off the 12V outlet on the dash.
Dean P
Florida
Chaparral
VRX
That looks really good. Great job! Ram mounts do make life easier.
KevJul2019
Harrison Twp, Michigan
Where did you mount the transducer?
Maccam26
Winston-Salem, NC
I went with a SIMRAD GO7, a little over the top for the size of dash but it's awesome.
mrtrav
Ridgefield, WA
AR195
Which Ram Mount model number did you end up going with? It looks like there are 4 of them on their website for the Striker 4.
marcham
Comox, BC
AR195
I believe it was RAM-B-202-G4U
mrtrav
Ridgefield, WA
AR195
Did you install the transducer yourself? I'm a bit nervous about drilling holes in the hull.
