Welcome to Jetboaters.net!
I figured what's the point of flying a flag at night???? Also I was thinking I bet I could turn it into a flag pole / light with a little modification..
I thought about that too, zip tie it, I just thought the telescoping deal was cool, figured you could have it in the down position if you were going to be WOT a lot, I would think the light pole we have would be strong enough, I really was wondering about the socket, if it would be strong enough..
I also just zip tie to the tower, however I zip tie to a quick release key ring top and bottom and opposite end through the flag hole. To remove slide lock and it is released. Takes 1 second. Can be purchased most places that make keys.
I actually purchased one of those poles. http://www.ebay.com/itm/161248043171 SAD MISTAKE. If ya decide to "open 'her up" ......... you may discover your flag floating somewhere in the lake. I am now looking for a better solution. This pole AIN'T it ! Not if you are interested in a SECURE pole ! Best Wishes, Mikey Lulejian - Lake Oconee, GA
I also just zip tie to the tower, however I zip tie to a quick release key ring top and bottom and opposite end through the flag hole. To remove slide lock and it is released. Takes 1 second. View attachment 4492 Can be purchased most places that make keys.
I think I better clarify what type zip tie I use. I use the type that that has a small loop on the end. I then thread the key ring through the loop prior to fastening to tower. This prevents the key ring from scratching the tower. I will post a picture tonight of zip tie to eliminate any confusion.
$45 at West Marine for a Taylor Made pole and surface mount. I wouldn't attach it to the light pole, you are asking for a cracked socket or lost pole and flag.
