YamaHog
- Little Rock, AR
- Limited S
So I've done some searching and reading on past threads and it seems that Yamashield, CRC 6-5-6, and Fluid Film seems to be the top choices for corrosion protection on hardware and engine parts, so after reading I decided on CRC 6-5-6, but when I went to buy the stuff, it seems to be the ONLY CRC product that nobody seemed to have. At my last stop at O'Reily's I ended up picking up some Fluid Film and tested it our today on the some locks and screws. Seems to work well, but appears to leave a brownish/yellowish residue. Do I just need to shake the can up better? Should it spray clear or have this yellowish tint. I was planning use it for corrosion protection on my engine as well are all hinges and metal parts on the boat It seems most people that use this stuff swear by it. It seems to be safe to apply to almost anything with it's non-corrosive lanolin base. Anything I shouldn't use it on? Insight from others using this product is appreciated. Planning to used it on the boat trailer as well but don't want to leave a brownish/yellow mess on everything.......especially my engine!
