  • Jetboaters Sale Link - Smaller
    SHOP THE JETBOATERS.NET SALE NOW
    This Notice Can Be Dismissed by clicking on the "X" in the upper right>>>>>>>>>>>
FSH 252/255 Trailer Brake Project
Zackdadams
MS Gulf Coast
Tutorial for replacing brake calipers, surge actuator, rotors, and more.
Now a disclaimer: I am not a mechanic.
There are most definitely steps that could be improved in this tutorial!
Tools Needed:
Part 1: The Calipers, Rotors, & Leaf Springs
I live on the Gulf Coast, exclusively using my boat in salt or brackish water.
Each time, I rinse the brakes down with water, afterwards I use salt away, and follow it up with fluid film.
However, saltwater is a beast, so it's time to do some maintenance, replace my calipers, and refurbish or replace anything else needed on the trailer.
You will want to buy lots of Water Displacement Formula #40 for this install!
Step 1: Disassembly & Decisions
Remove your wheels and tires.
Once they are off, you should be able to get a good look at the state of your brakes, calipers, rotors, leaf springs, & brake lines.
In my circumstance, i'm replacing the calipers, and going to refurbish everything else.
Start by removing the brake lines screwed into the calipers, with a small box wrench.
Wrap the ends of the brake lines with paper towels and painters tape.
Note: The starboard side calipers have 2x brake lines each.
We will be reusing this 2-port valve off the old caliper.
Step 2: Remove the Calipers
You will use a 3/8 allen wrench socket on the back side of the caliper.
They are in very difficult locations, so you will probably want to buy a swivel knuckle for your socket set.
I ended up having to use a piece of pipe on the end of my socket wrench to initially break the nut free.
Once both allen bolts are removed, you may have to use a dead blow mallet to persuade the caliper off the rotor.
Step 3: Hub & Rotor Disassembly
  1. Remove Dust Cap
  2. Spin the rotor while gently tapping the central hub with a rubber mallet.
  3. Remove the cotter pin.
  4. Remove the nut.
  5. Pull the rotor towards you, releasing the bearing & washer.
  6. Catch these with a paper towel, as they are covered in grease.
  7. Use a flat head screwdriver to release the clips inside the grease hub.
  8. Separate the spring, clips, & zerk cap.
  9. Remove the rotors.
You should now have these parts in front of you.
Step 4: Refurbish or Replace the Rotors
My rotors weren't that bad, so I decided to keep them.
Your situation might be different.
Take the rotors to a professional shop.
They can turn the rotors, giving them new life.
Alternatively, buy new rotors.
I took them to my local mechanic, and he turned the rotors for me.
Step 5: The Leaf Springs
At this point, take stock of the condition of your Leaf Springs.
Mine are still decent, so I opted to Sand Blast, Prime, and Paint.
Tape up your spindle and brake lines.
Use a wire brush to scrape off the rust, and follow up with a light sand blasting.
I purchased this light duty model from Harbor Freight.
Afterwards, spray Acid Etching Primer, followed by Black Rustoleum.
Step 6: Grease, Grease, & More Grease
Clean all your parts using a combination of paper towels, Parts Cleaner, & rubber gloves.
Once everything is cleaned, apply a generous amount of marine grease to the spindle, bearings, and interior of hub.
I'm using Lucas Marine Grease which is designed for boat trailer bearings.
Afterwards reassemble the hub.
Finally, use a grease gun on the zerk fitting to fully the grease the hub.
Here's a great video explanation of greasing and reassembly:
Step 7: Attach the New Calipers
The new calipers are Dexter DB-35 Aluminum.
(2) Left Side #42015L
(2) Right Side #42015R
Caliper Installation Steps
  1. Replace & install the 2-port valve on the starboard side calipers.
  2. Use a C-clamp to compress the central piston.
  3. Apply very small amount of caliper grease to brake pad ears.
  4. Clean Rotors with Parts Cleaner.
  5. Install New Calipers over the Rotor. (Make sure the bleed valve is on top!)
  6. Install New Bolts
  7. Bleed Brakes after Surge Actuator installation. (explained in next section)
Here is the finished product, before & after.
Note: The Brake lines are strapped to the trailer frame with metal clips.
Mine had pretty much rusted away, so I removed them.
I used large zip ties each foot to re-secure the lines.
Afterwards, I sanded, primed, and painted the axel black.
Finally, take this opportunity to slap on some new wheels and tires!
Tools Needed:
Part 2: Surge Brake Actuator
The Surge Brake Actuator for our Shoreland'r Trailer:
Dexter DEX-099-060-20
UFP DX7.5L A60 Disc Brake Surge Actuator - Tandem Axle
My actuator had locked up, so it was time to replace it.
It's held in place with 2 large pins & 4 snap rings.
You will need Snap Ring pliers to remove them.
The pins appear to be aluminum or some other soft metal.
Don't hit these directly with a hammer or else they will deform, forcing you to break out a grinder to reshape the heads
(Ask me how I know)
I found a landscaping stake worked perfectly for driving them out, with extreme persuasion!
Once I removed the old actuator, I discovered the brake line had broken off at some point.
I ordered a replacement hose: Dexter 76" Replacement Brake Hose
As you can see, the interior has obviously been holding water, causing rust
I plan on addressing this to prevent it in the future.
Start by removing the pin, then folding the trailer tongue in half.
My 7-pin hitch cord was in bad shape, so I picked up a new one at the local parts store.
Next, I used Parts Cleaner inside the tongue.
Afterwards, using a paint stir stick, I coated the interior with Marine Grease.
I also sprayed the inside of the actuator with White lithium Marine Grease.
I then replaced the brake hose, ran it back through the tongue, and attached it to the new actuator.
Finally, reinsert the new actuator, grease & reinstall the pins/snap rings, and rewire.
I added heat shrink caps to these connections but forgot to take a picture.
I then zip tied the wire bundle, and gently pushed it back into the tongue.
Fold the tongue back into place, reinsert the pin, and prepare to bleed the system.
Part 3: Bleeding the Brakes
Here is a great video on bleeding the system using the Motive Power Bleeder:
The basic idea is to pressurize the lines, then start bleeding the air out.
It was simple enough using the Motive bleeder.
There are other ways to do it, but i'm happy I went this route.
EDITING IN PROGRESS 🚧
Incoming tutorial for replacing brake calipers, surge actuator, rotors, and more.
Tools Needed:
View attachment 231446 View attachment 231476
View attachment 231443 View attachment 231477
  1. Remove Dust Cap
  4. Remove the nut.
View attachment 231447 View attachment 231448 View attachment 231449
View attachment 231450 View attachment 231451 View attachment 231452
(Don't do what I did: Watch YouTube.
Use a grinder with a flap disk to clean them up.)
View attachment 231456 View attachment 231457 View attachment 231480
View attachment 231458 View attachment 231459
View attachment 231463 View attachment 231464
View attachment 231465 View attachment 231468
Zack, what an awesome post!! As usual extremely well done!!
S
Finally finished with the project.
Took several weeks.
So Zack,
That pressure bleeder, it goes into the reservoir and there is a metal plug if you will that fits snugly in the rubber lined opening of the reservoir? May I ask where you got it and how much it was?
That system looks like the bomb for bleeding the brakes! Much easier than using a screwdriver on the plunger in the actuator. That would make that a part of annual servicing very easy!
Yes to the above.
I linked the parts in the 2nd post, but it was around $100 on Amazon.
Thanks! Looks like you got the last one from Amazon….
But one can still get them from the manufacturer…direct.
It was a breeze to use.
Added a quart of fluid, and only pumped it up once.
The bottle was nice to have also.
Made a tight seal on the valve.
