TOGA
- Chattanooga, TN
- SX
This is the year my well maintained and always reliable 2006 is showing its age.
Last weekend while running down the TN river, I looked down and my fuel gauge was gone.
Just a hole in the dash.
When we stopped running, I looked in the compartment below the console and found the gauge in amongst the wiring harness.
It wasn't hard to understand how it mounted and what had happened.
The face place had broken from the gauge and the beaty ring was still on the console.
I brought it in, super glued it back together for a quick fix and reinstalled it today.
Now it doesn't work.
The red light flashes once when you turn the key to power, but the needle doesn't move at all.
I have perfect pass spliced in for power at the switch and perfect pass does turn on, so because of that (and the red light flash) I know it is getting power.
The gauge was working when I disconnected (if I remember correctly). Pretty sure I remember checking fuel level before disconnecting.
I checked for any other connections / fuses under console but see nothing.
I checked connection at fuel sender and it is connected.
I do have the new fuel sending unit upgrade.
Anyone have any ideas or things for me to check?
