- X
Sorry, not jetboat related, but needed some opinions form the modifiers here. I have a 25 gallon fuel tank on my pontoon boat, located under the rear lift-up section.
I'd like to add the ability to fill the tank from inside the boat.
I'm looking to either cut a hole in the tank top and add in a screw in cover/cap, or to add a t-fitting to the fill hose, and a cap . I'm starting to look now for fittings or pieces that can be used or modified to work.
Any inputs? ideas? known parts
I don't have access to the inside to bolt something like this. would potting it in a big goop of 5200 make the grade ?
https://www.amazon.com/Aluminum-Remote-Filler-Flange-Assembly/dp/B01N265YJ5/ref=sr_1_4?s=automotive&ie=UTF8&qid=1531748390&sr=1-4&keywords=Fuel+Cell+Gas+Tank+Filler+Neck
